Repairing a sync cable
Started by Lndr ·
  1. Has anyone out there repaired a sync cable?
    I have an Ikelite sync cable with some recently added chew marks in one end ... :glare:
    Not surprisingly the cable doesn't work anymore. I'm wondering if it is possible to cut off the damages couple of inches at the end and re-attach the plug?
  2. Has anyone out there repaired a sync cable?
    ..... <cut>
    Yes, and worth taking a fine soldering iron and solder on trips as may not be readily found. I had to use a lighter to heat a copper wire to do the soldering with.
    Charles
