Strobe needed for Canon S80/Ikelite # 6140.08
Started by jzsj0 ·
  1. Hi All,
    I'm off to Malaysia for 2 weeks in August (can't believe I've had to wait a whole year before diving again :) ) and currently I've got a Canon S80 with the Ikelite housing.
    Whilst it took good pictures on my last trip to Sharm I feel there's much more to be had out of the camera with a proper strobe.
    From previous threads, I'm thinking the Inon Z-240 1) because of the positive feedback, size, weight, and standard battery capacity, and 2) it'll be future-proof if (when cash allows) I can upgrade to a proper u/w DSLR system.
    2 q's if I may for the experts:
    1) Any other options worth recommending (Ikelite strobes obviously come to mind)?
    2) I've already bought the Ikelite #9523.31 release tray so what else would I need to get the whole ball joint et al setup in hand?
    Many thanks all - can't wait to get back in the water :)
    James.
  2. Hi James,
    You can start with the D-2000. It's several hundred dollars less than the Z-240. When you get a DSLR, you can buy the optical trigger for about $250. It's roughly the same strobe.
    I haven't used an Ike strobe, but plenty here have.
  3. I have been using a Canon S80 with the Inon D2000 too. really like the strobe. only difference is I have the canon housing which worked well for me too.
    MJ
  4. Hi,
    Thanks both for the reply. Interesting comments on the D2000, but I couldn't find it *that* much cheaper than the Z-240 - cheapest I found was at divervision.com, 499 for the d2000 and 669 for the Z-240.
    Anywhere else that's cheaper?!
    James.
