flooded strobe (it survived)
Started by poetazzo ·
  1. hi, i'd like to share my flood story with you
    i'have a dslr system with 2 strobe, ys-110 as primary and ys-90A as slave
    yesterday i was in a boat for 3 dive , 2 in the morning and 1 in the evening.
    during the first and the second dive every thing works fine and as usual i shot some picture
    both dive was about 15 meters deep
    during the evening dive i took some picture but aftere a while the slave strobe die.
    i was thinking at a battery issue but when i arrived on boat i found the battery conpartment was full of water :(
    after i cleaned the strobe i was sure it was died and i was prepared to fight with my seller because the strobe was almost new.
    today i was at the shop and the seller put 4 new battery in the strobe and..... miracle!! the strobe still survive ;);)
    he told me that the ys strobe has a separated compartment for battery and strobe's electronic so if you flood the battery the strobe survive :)
    now he will clean the battery contact,test the o-ring and the strobe will be as new :D
    hope that this story will be usefull to someone
    byebye
    albe
  2. I am glad your strobe survived! Did you find any reason that it failed?
