a few questions about Ewa Marine housings
Started by d3sertdiver ·
  1. Hi,
    I have a Canon EOS 400D\Rebel XTi. I was thinking of buying an underwater housing for it and since the hard case housings are way out of my budget I'm considering buying the Ewa marine.
    1. Pressure damage: since it's a flexible housing the pressure that will be in the water will be the same inside the housing. The U-AXP has a depth rating of 50m, hence it will be 6 times normal atmospheric pressure, if there are any air pockets in the camera then won't it get damaged? for example the flash bulb.
    2. Flash: How effective will the external flash be underwater?
    3. will I be able to operate the dial?
    Does anyone have experience with the U-AXP and the external flash? It would be nice to know.
    Thanks in advance
  2. Hi,
    Thanks in advance
    I think the Ewa marine bag is not really an option for scuba. Perhaps for snorkeling...if you're not a very good snorkeler that is.
    /c
  3. I think the Ewa marine bag is not really an option for scuba. Perhaps for snorkeling...if you're not a very good snorkeler that is.
    /c
    I read here on wetpixel on past posts that there are people that do use them with still and video.
    Any particular reason why you dislike the Ewa marine bag?
  4. The Ewa bags are not made for scuba diving use. They are designed as water protection for extreme shooting, snorkelling, and pool/commercial type shots.
    They have a flat port only. The housing compresses with depth. If you plan to take it below a certain depth, you are supposed to "inflate" the bag before going down.
    I think you could use one for snorkelling and pool photography. It would WORK but not well for diving to say 10 meters. Use at your own risk.
  5. The Ewa bags are not made for scuba diving use. They are designed as water protection for extreme shooting, snorkelling, and pool/commercial type shots.
    Thanks for the reply, :D
    Guess I'll just have to stick with my old canon A610 for now :D ... The hard case housings are expensive for me right now, or buy the ewa housing for snorkeling until I can get enough money for a better housing.
