Help with Sea@Sea ports
Started by miguelcortes ·
  1. Hi,
    I'm thinking of buying a Sea&Sea DX-5D housing and I've seen the ports that I need in the Sea&Sea web:
    - for the Sigma 15 mm and the Canon 17-40L the port is the NX Fisheye Dome Port (56401)
    - for the Canon 100mm f2.8 macro USM, there are two options: NX Custom Flat Port or DX Macro Port 50 with DX Macro Port Base
    I don't like those ports for the 100mm because are very big and no possibility to use wet close lense like woody's diopter.
    Somebody have tried the following option?:
    NX Compact Macro Port Base ( 56201)" and "Compact Macro Port 52 (56241)"
    Are there another flat ports for de 100mm in DX-5D housing?
    Thanks.
  2. You may want to consider this port from Athena, it allows for a 67 mm close-up lens like the Inon M-67 and the Athena ring flash. athena-opt.com
    Regards
    Phil Rudin
    Edited by tropical1
