Bought: Wet mount Wide-Angle threaded mount lens
Started by justin-branam ·
  1. Im looking for a wet mount WA lens to use on my p&s video camera. housing has 55mm threads, but i can always get adapter rings so let me kow what you have. The wider the better, and a big plus would be something that will work above and below water (i think the old sea and sean ones do but they are bayonet mount).
    you can pm me or email me at "stitch AT houston DOT rr DOT com"
    Edited by justin-branam
  2. I have an Inon UWL100 Type 2 (67mm thread) with the Inon UWL-100 dome unit (increases the underwater field of view from 100° to 131.6°) that I am about to put in the classifieds if this is of any use to you.
  3. Hi,
    I've got a Sea and Sea nikonos 16mm wide angle for sale (see my ad below) It is a threaded lens, and have used it with an adaptor ring.
    When you do this, you o get some vignetting at full camera wide angle-just zoom in a bit and it works fine! I reckon I get about 100 degrees of view.
    Hope that helps!
    Adam
  4. FOUND! Thanks Gudge.
