Jing, To be a little more clear, if you are looking for an algorythm that tracks the way the older style Aladin Pro (grey style worn on wrist or in console) then there is no current Uwatec model that does this.
Uwatec came out with the Aladin Pro in the 80s which tracks the Buhlman ZH6 (6 compartment tissue group) and this was a more aggressive algorythm than the current ZH8 and ZH8 ADT algorythms are. Its easy to tell if you have one of these "first generation" Aladin Pro computers as there is a small circular cap on the top to one side with two holes in it. This is where the battery compartment is.
The "second generation" looks very simliar to this but without this cap. The other tell tale aspect is the number of wet-contacts on the front. The older first generation has two on the bottom row and one on the upper right, it also only holds 9 logged dives. The second generation has three contacts on the bottom and the single on the top right. Further, the 2nd gen allows you to check the battery percentage left, the old does not. There are other features not to go into here.
If you have the "second generation" model, as stated, this is the Buhlman ZH8 which tracks 8 compartments and is slightly more conservative than the 1st gen. but not as conservative as the Suunto models. The second generation of models came out in the 90's. If you get another of the newer Uwatec computers you will get one that includes the ZH8-ADT model that adapts to temperature. Any of the latest styles with Microbubble Suppression Algorythms are all ZH8 models but with the ability to make the model more conservative through user-adjustable MB levels - these are not Decompression stops but are instead Level Stops for further offgasing and conservation.
All do a great job but the first generation is definitely more aggressive than all the others. You usually find the 1st generations still being used by some of the "techie" crowd but they are a lot less common to see. First generations also were distributed by Uwatec, Parkway, and Buchat. I could give you more detail but I've bored everyone enough. Good luck and have fun diving!
