which ring for 10.5/Subal FE2/2xTC
Started by cor ·
  1. Hi all, which ring is the best one to use for the Nikon 10.5 in a Subal FE2 port with a 2XTC? I tried the 33mm but the images look a bit soft..
    Cor
  2. Hi Cor
    Sorry can't help you.
    Could you explain the interest of using wide angle with a teleconvertor ?
    Thanks a lot.
    Sven.
  3. Hi Cor,
    I use an 8 mm fisheye with a X 1.4 teleconverter in my Olympus housing. It puts a little mors distance between the dome and subject. Image F 5.6 at 1/90th ISO 100. Subject about three inches from dome.
    I use the same extension ring I would with a macro port and the teleconverter.
    Phil Rudin
    Edited by tropical1
