SB105's & Seacam
Started by Hansen ·
SB105's & Seacam
  1. Hi
    I am trying to set up 2 x SB105's with my Nikon F90x (n90) in a Seacam housing... the slave is not working properly - the solution must be a dual controller!? Can anyone suggest a make/part. no for such a device?
    Greetings from Sweden...
    Martin
  2. Are you using a dual sync cord, or two single cords? If not, just try a Dual Ikelite or Nikon made cord. I recommend the Ike because it uses a delrin connector.
