My first rig
Started by Pilgrim ·
My first rig
  1. Okay am getting my first set - up
    am getting the
    canon A 710 is with the ikelite #6140.71 housing. Any comments?
    but what i really would like to know is what strobe? and how does slave mode work, is it just a pad in front of the flash? stuck on with what?
    i looked a fuji that said it was wireless?? am confused on that one.
    am looking at the Epoque ES-150DS Alfa Strobe ? any comments?
    Any advice greatly appreciated
    would like to spend about GBP150 about $300
    cheers
  2. Okay am getting my first set - up
    am getting the
    cheers
    The day you purchase an Ikelite housing, you are going to be taken care by Ikelite :-)
    Which means strobes and everything, it could be good and it could be limiting .... IT's good for the most part. Ikelite strobe offers a "manual EV" trigger system which basically picks up the flash from the P&S camear and then fire the strobe. The Manual EV controller is an optical sensor that senses your camear flash light when it execute. The manual EV connects to the Ikelite strobe via a cable. The strobe can be DS51 or DS125 (highly recommended), those 2 are the most popular. When the camera flashes, the EV controler picks up the info and then fire the strob via the cable.
    Slave mode basically means no pre-flash so when the camears flash goes off, the Manul EV goes to work too. http://ikelite.com/web_pages/mansensors.html
    Slave mode is a camera setting, check the camera to see if it offers slaves mode flash. Most do, just need to know how. If it doesn't, get a different cameara instead !! With Ikelite system because they have a manaul EV that mount on the handle bar, no nasty mounting require. Other mounting require you to put a valco or something in front of the flash light ..... P&S w/ manual EV and some Ikelite strobe are perfect getting started system.
    Don't buy Epoque, many of us had Epoque, they always ended up flooded despite how secure it may be locking the battery compartment but it will flood somehow ! Get a Ikelite DS51 for your system, it will work well !
    Edited by CADiver
