Please help with Sea&Sea ports
Started by BIKO ·
  1. My friend will get soon his Sea&Sea housing for The Nikon D80.
    At the moment he is interested in purchasing ports for his Nikon 60mm macro,
    and for his old kit lens (18-70mm, should it be dome or flat port+zoom gear BTW?). I find the
    Sea&Sea site and documentation very unclear. Can any one post the product
    numbers of the correct Sea &Sea ports, so he can make his order?
    Thank's,
    Dany Weinberg
    Edited by BIKO
  2. My friend will get soon his Sea&Sea housing for The Nikon D80.
    Thank's,
    Dany Weinberg
    I use 56261 with 56201. I make an educated guess it will work for you. Someone please correct me but I only have 105mm macro lenses, but it will also work with full-frame film as well as Nikon D200
  3. I use 56261 with 56201. I make an educated guess it will work for you. Someone please correct me but I only have 105mm macro lenses, but it will also work with full-frame film as well as Nikon D200
    Hey John !
    have you changed your email addy lately, i've mailed you a couple of times but got no response, maybe you just ignorning emails from a northerner !
    Hope the D200 & Sea & Sea is treating you well.
    with relation to the question raised above, here's what i use and its works just fine
    18-70 is used behind the compact dome port with a 40 extension ring and 18-70 zoom gear. & a +4
    60mm is run using a compact macro port base along with the small compact macro port.
    If i run the 105mm i simply add the 40 extension ring to this and its as simple as that.
    i also use the 12-24 with the dome and extension above
    the 10.5mm us run in this dome without extension.
    Simple
    regards
    craig
    Edited by craig nelson
