D100 Dual Cord
Started by doubleblue ·
D100 Dual Cord
  1. Hi Folks,
    I have a new Aquatica D100 and am very happy with it.
    I can't seem to get it to fire using the dual cord, however.
    I think this is a D100 issue.
    What am I forgettint to turn on or off to get this to finction??
    Best,
    TR
  2. Hi TR,
    Hmm...doubleblue....that sounds familiar...:-)
    What strobes are you using? Are you using a manual sync cord or a 5 pin sync cord?
  3. Hi There,
    Hmmmm?--could be any number of the items-OK first check the Flash mode custom setting in the D100 is to MANUAL,then establish the Flash Sync Mode is set on Front curtain sync ( only manual U/W remember with D100+flash).Set shutter speed for 180 or below.
    As for the leads themselves-well open pin firing/continuity checking the contacts/etc will validate their correctness to work as per.
    If all this fails-heaven forbid--you could have a polarity problem in the trigger voltage (+- need to be reversed in the leads-ugh- cut and switch!).
    Good Luck,
    Lyin :P
