I have been having intermittent issues with overexposure using iTTL with my D70 in an Ikelite 6801 with one or two DS125 substrobes. The housing and strobes are new enough that they have the latest iTTL circuitry. Sometimes the photographs are well exposed and other times they are grossly overexposed. The overexposed images happen more frequently when I'm using a the Micro 60mm lens compared to zoom lenses. In fact, I'm not sure I ever had the problem with the 18-70mm kit lens, but it does occasionally happen with the 18-55mm II.
With the 18-55mm II, the problem comes and goes. With the Micro 60mm, I usually have to switch the master strobe off and on to "clear" the problem.
I don't have an iTTL flash for land use, so I can't determine if the problem happens without the housing or not.
Has anyone else had this problem?
