CS3/Lightroom Migration from Elements
Started by danclem ·
  1. Greetings:
    I am in the process of migrating from Photoshop Elements to CS3 and Lightroom, and working on overcoming what looks like a fairly steep learning curve.
    Do any of you Photoshop junkies know if there is a routine in CS3 or Lightroom that is the equivalent of Elements' Quick Fix> Lighting> Levels/Contrast to quickly adjust colors underwater?
    Thanks!
    Edited by danclem
  2. I haven't used Elements, but if you do:
    Image > Adjustments > Auto Levels
    does this achieve the same effect that you're looking for?
  3. Hi:
    I find that this darkens the image quite a bit. The Image> Adjustments> Contrast/Color seems to work best, but I then need to lighten it up a bit. This step was pretty "idiot proof" in Elements, and I have a feeling there is an adjustment somewhere that I need to togel on.
    I am also really curious if Lightroom can do the same thing. It is a very interesting program.
    Dan
    Edited by danclem
  4. Does Auto Colors (in the same window) behave any differently for the image in question?
  5. I believe that in Lightroom you could adjust one image using the develop screen options, and then copy to the other images; or even better save as a develop preset to use when needed.
    There are auto options in the Library section of Lightroom also that you could try.
    Good luck,
    Kathy
