Hi Lou,
I don't like the compact wide port solution because that port is a flat port and you're going to loose 25 percent of your angle of coverage with that port, along with getting what is called pincushion distortion on the edges. Using the fisheye dome port (which you have for the 10-22 already) is the best way to go even though it's not listed on the port chart. You'll maintain the same angle of coverage on land because the dome cancels out the refraction between water and air. You'll also need an extension ring 40 and a plus 2 diopter on the front of the lens. The extension ring will get the virtual image further away from lens and the diopter will help sharpen up the corners, especially on the wider end of that lens.
The best setup for the 10-22 lens is also with an extension ring 40 and a plus 2 diopter, so hopefully you have those items already. They don't list this in the port chart either, but field testing has proven this to be the best combo.
You'll also need the zoom gear. If you already have the diopter for the 10-22 lens, you can get a step down ring to fit the 18-55 lens so you can save some money by not buying another diopter.
Hope this helps you get setup right.
Jim
