Copyright symbol
Started by cdoyal ·
Copyright symbol
  1. I can't find the symbol with CS2's type tool. Any help would be appreciated!
  2. I don't use Photoshop, but you can get the copyright symbol in text (with any Windows application that supports text) by typing Alt-0169 on the numeric keypad. i.e. hold down either Alt key and type 0169 on the numeric keypad and you will get ©.
  3. I can't find the symbol with CS2's type tool. Any help would be appreciated!
    On a Mac press © OPTION-G, may be the same for PC (been awhile since I did that :))
  4. In Microsoft Word you also can press CTRL+ALT+C and then just paste it..
  5. I use the Character Map application in Windows
    that lets you copy and paste, plus you can see the symbol in different fonts easily
    HTH
  6. Or you can use the copyright symbol that's in the default custom shapes, if you're looking for simple....
  7. I don't use Photoshop, but you can get the copyright symbol in text (with any Windows application that supports text) by typing Alt-0169 on the numeric keypad. i.e. hold down either Alt key and type 0169 on the numeric keypad and you will get ©.
    That works great! Thanks!
