Minolta DiMage 7Hi
Started by candele ·
Minolta DiMage 7Hi
  1. Anyone know if any manufacturer has/is produced a housing for the Minolta DiMage 7Hi. I've already checked Digideep.com with no luck so I thought I would try this group before giving up on the camera.
    Thanks, Ed
  2. It is impossible or very hard to make a housing for cameras with long retracting lenses like 7Hi or coolpix 5700.
    If you zoom out max the lens will bump into the housing or you will get vingetting in the corners of the picture when zoomed in, 7hi has a 28mm and it will get darker corners just by putting on a to think UV filter. A housing can not be done unless you use it without zooming.
    To bad I have the camera and it is excelent .... for land use!
    you can put it in one of the plastic bags though, is OK for snorkeling but nothing serious.
