Since my leek detector died in heroics when buzzing around when the housing was leek, I removed it but some glues marks where stayed inside the housing, hot water and soap do nothing so I'm looking for a way to remove the glue without harm the Ikelite's housing.
Any advice what to use?
3M General Purpose Adhesive Cleaner, Part number - 08984
This stuff works great,
Marc
Thanks Mark,
I looked for that item around where I live and found nothing.
Is there a simple product that can be bought in and pharmacy or DIY shops that can do the work without harm the housing, since its small area I don't mind to work harder with less appropriates product.
Thanks Mark,
You can buy most 3M products from a good automotive supply store. They use this adhesive remover to take off residual glue from car graphics. I use it to take off silicone from my dome ports and acrylics without harming the surface.
Marc
Just an update for the solution: I finished cleaning the glue by white gasoline that can be bought in any pharmacy, the 3M cleaner that Mark suggested was impossible to find it around here and a colleague suggest the gasoline, its works great, cleaning without any mark on the housing.
