I have a nikon d80, sea-n-sea housing, tokina 10-17mm lens..
A couple people on this board recommeded the zoom gear for the canon 18-35mm, they said it would work...
well, it fit on, barely... the zoom gear was almost up against the camera body, but it seemed to work... worked well on my dives, except that during two dives the zoom gear came off the lens and fell into the dome port.
actually a couple photos I took that way looked pretty cool! I was able to get it to slip back on the lens by holding my pointing my camera up, although if I pointed it down it sometimes slipped back out.
I think it might have been my fault that it came off, I might have turned it too much in one direction, because I wasn't used to which was zoomed-in and which way zoomed-out.
it felt tight enough, but maybe I should try the thicker o-ring it came with? or maybe it was just because I forced it in one direction.
anyways, I'm curious to see if this ever happened to anyone else, and what they did about it.
is anyone else here using the sea-n-sea canon 18-35mm zoom gear with a sea-n-sea housing, nikon body, and tokino 10-17mm lens?
scott
