How to add one more strobe
Started by Joso ·
  1. I'm now using D80 Ikelite with YS90 and would like add one more strobe. Other than YS90, is there any other option, say Inon 240 or DS125?
  2. I dont think ikelite makes dual cords with different connections on the strobe end. So I think you ar forced to remain with sea and sea.
  3. I would call Ikelite about this one, because they might be able to rig up something custom for you. They've been able to do all sorts of crazy things for me if I just ask.
  4. Why worry about hard wiring a second strobe when you can choose from so many that will work from slave flash? You can then choose from nearly all manufacturers lists and all sizes and power ratings.
    I am personally thinking about using a slave fired S&S YS27DX as a fill flash at the moment. It's small and manouverable and if not needed can be turned off.
    Bruce
