Sea & Sea O ring's
Started by jethdlr ·
Sea & Sea O ring's
  1. Greetings,
    Have a question maybe someone can help. I have a DX 200 and still shoot a NX 100 Pro. The housing O rings seem to be the same. No one knows (or wants to stick their neck out :blush:) if they would be interchangeable as the port O ring.
    Anyone know the answer or good guess.
    Jay
    Edited by jethdlr
  2. I wouldn't interchange the main housing o-ring, but I'm sure the port o-rings are interchangeable, as the port system is still the same. Sea&Sea o-rings are blue, correct? If both are the same color/width I wouldn't mind interchanging them. If you are still hesitant, change the o-rings and dive with the empty housing (on freshwater) just to check.
    Luiz
    Edited by Rocha
  3. I wouldn't interchange the main housing o-ring, but I'm sure the port o-rings are interchangeable, as the port system is still the same. Sea&Sea o-rings are blue, correct? If both are the same color/width I wouldn't mind interchanging them. If you are still hesitant, change the o-rings and dive with the empty housing (on freshwater) just to check.
    Luiz
    Luiz,
    Good thought. The S&S O rings are the blue silicon impregnated ones. The port O rings are the same but the catalogue number for the D series main O ring are different that the NX ones.
    Sea & Sea will most likely quit supporting the NX 100 Pro so just looking for some options down the road now that Fuji is reintroducing Velvia (still better than digital IMHO :blush: )
    Ciao
