More questions about polishing an acrylic dome port
Started by msblucow ·
  1. Following the techniques I learned here, I ended up using a Micro-Mesh polishing kit to polish out some large scratches on my acrylic dome port. I'm largely satisfied with the end result, but I noticed there are still some fine cross-hatching for about a 1/2" along the edges. This was the most difficult part of the dome port to work on. However, when I flushed the port with water, the cross-hatching completely disappears. Should I just ignore this like I would any other fine scratches that would fill with water or should I continue to work on the edges until the marks disappear?
    Marta Evry
  2. If it does not disturb why continue?
    Just be sure it does not appear in sunny conditions as mentioned here few days ago.
  3. I won't be able to take it into the water right away, but I did hold it up to the sun at a right angle to see if I could find anything obvious. I think I'm good, but again, taking it underwater would be the real test.
