Sea and sea ttl converter and inon z-240 strobes
Started by Jez_Tryner ·
  1. Hi there,
    does anyone know if the Sea and sea ttl converter and inon z-240 strobes work together to give reliable ttl lighting?
    i can't seem to find any info on this online and sea doesn't recommend it, surprise surprise, inon says it will work but I would like to see if anyone is actually doing this, straight from the horses mouth sort of thing,
    many thanks in advance
    Jez
    plus would love to hear from anyone who has had any problems with sea and sea conveter, i have heard that there may be some melting issues, doesn't bode well.
  2. I've mentioned before, but I think that the post was removed because of names named: I've seen some pretty fierce corrosion problems with a Sea & Sea TTL unit, where the strobe and camera cables were almost welded to the TTL unit.
    Tim
    B)
  3. Hi there,
    Jez
    Aren't there whole threads on this compatibility. The search function thinks so.
  4. I have the second generation on 2 Subal D-200/Inon 240 systems, and have not had any problems.
    They work well for both W/A and macro!
