Sea and Sea Nikon TTL converter III
Started by downunder ·
  1. Does any one know if the new Sea and Sea TTL Converter III fixes the problem with corrosion with the Nexus housing due to the TTL converter having a positive ground.?
    I have been using the TTL converter II with nylon bolt and insulation and all is well, however the new converter looks totally redesigned ?
  2. Does any one know if the new Sea and Sea TTL Converter III fixes the problem with corrosion with the Nexus housing due to the TTL converter having a positive ground.?
    I can't confirm yet, but Yuzo Kanda reccomends this converter for use with nexus housings. There is a possibility that this is the case. I have one on order but I'm not sure I'm ready to give up the plastic bolt before I know more about the new converters performance.
    Espen :)
  3. I have alread gone mine from Yuso, they have changed the way the battery in installed negative now to outside. And the housing is all plactic not with no place to earth to outside. I don't know if it fixes the problem but it looks like it may.
    It looks like their designers have taken on the problems with the previous version and improved it. :angry:
    Edited by downunder
  4. Hi Espen,
    I would just like to ask your opinion as to the S&S TTL converter that you currently use.
    Do you get reliable performance from it, with regard to consistent, even exposures, or do you find that you are making a lot of corrections with either exp comp in the camera or PS alterations post op?
    THNX,
    Bruce
  5. Hi Espen,
    THNX,
    Bruce
    Hi Bruce,
    It does give me very consistent results with a few exeptions. The converter will need adjustment when:
    - shooting subjects that are transparent (non reflective)
    - subjects that don't fill the frame more than 20-30%
    - using very large arperture values when shooting close to the strobe. The cameras electronics are to slow to shut of the sudden powerful burst of light from the strobe. This was a problem with film also but not as severe.
    Any compensation I do I do on the converter itself. Its hands on and more easy than adjusting in camera.
    I like the system and the option of shooting pretty good i-ttl but also have the option to quickly switch for manual. Any fine tuning I do in raw, but most macro shots don't need an exposure change in raw.
    Espen :angry:
