WB or Filter in Canon A630
Started by ramaroodle ·
  1. New to Video. I usually shoot a D200 but just for kicks I am going to also use my friends Canon A630 on an upcoming trip to Roatan. He and I just got back from the Virgin Islands where he took many hours of UW video during the 2 weeks. He got the housing for it only a few days before we left so there was no chance to practice. Naturally, everything is blueish and needs to be color corrected.
    Should I be looking for a filter? Can I use my Magic Filter and slip it inside the housing, or is there a white balance adjustment on the camera?
    Andy
  2. New to Video. I usually shoot a D200 but just for kicks I am going to also use my friends Canon A630 on an upcoming trip to Roatan. He and I just got back from the Virgin Islands where he took many hours of UW video during the 2 weeks. He got the housing for it only a few days before we left so there was no chance to practice. Naturally, everything is blueish and needs to be color corrected.
    Andy
    Andy,
    First off is it possible to manually white balance your Canon? If so the way to go is buy a URPro Color Correcting filter, attach to your camera and manually white balance using your hand or a white slate. Do this every time you change 10 ft. up or down and you should see the benefits. The Quality of the Magic filter is far less then a proper CC filter. If no manual options then you have other options but with less results. I can elaborate more if that is the case, hope that helps.
    Scott
