Tokina 17mm ATX-Pro
Started by james ·
Tokina 17mm ATX-Pro
  1. Hi Gang,
    I use this lens and like it a lot as an ultra-wide (weitwinkel) prime. The lens is discontinued, but there is one for sale used so I thought I'd post something about it:
    http://www.fredmiranda.com/forum/topic/579201
    I dunno the seller - just posting for info.
  2. Thanks James. I was looking for one of these.
    Herb
  3. James. Have you used this underwater? If so, what port and how long an extension?
  4. I had read good things about this lens, and I got hold of one to try. I used it in swimming pool tests with an 8-inch dome and the Nexus custom dome for the Nikon 10.5mm fisheye lens.
    That was good...
    ... but the Auto/Manual focus selection on this lens is a monster, and it self-destructed after three weeks. The lens was unuseable and unrepairable
    As a result, I would NOT recommend this lens unless you can get it for a song.
    Tim
    B)
  5. Thanks for the info. I'll look up what Aquatica recommends for the 10.5mm and start there. I agree about the Auto/Manual focus selection. I plan on leaving it on Auto. In practice, for a lens this wide there isn't anything I can do in Manual that I can't do in Auto.
    So far I've been happy with the few top side shots I've taken with it. I got it used from the seller that James posted for about 260 songs, so it's not a big deal if it does fall apart.
    Edited by herbko
  6. Hi Herb,
    Yeah, I like this lens too - mine seems built like a tank. I use it w/ a fisheye dome and no diopter or extension ring.
