Matthias Heinrich TTL Adapter for D200 in Aquatica
Started by wolverine ·
  1. Hi guys,
    I have a question for on the above. Is it possible for the Heinrich adapter to work when strobes are attached to separate bulkheads? (ie The strobes are each attached to one bulkhead) Also, there are a couple of connections on the PCB board which the hotshoe can be connected to. According to the manual in the website, one is for the camera and the other is for power. However, I can actually get the strobes to fire when I connect to the "power" connection. Odd.
    The reason I am asking is that one of the strobes seems to be mistiming the fire. Can anyone help?
  2. Hi guys,
    Matthias can probably answer best, but my understanding is that the board has a single connector to the bulkhead, and you would normally have to use a dual strobe cord. However, it seems to me you could (if your electronic/soldering skills are sufficiently advanced) put a second ribbon cable lead from the strobe connector on the board to the second bulkhead, or connect the bulkheads in series.
    BTW, the board in a Subal housing with Nikon D200 and YS-110 strobes works great.
    Dave
