Nikon DX 12-24 mm lens with +4 diopter, final ratio?
Started by Deep6 ·
  1. What happens to the maximum ratio of a lens in a dome port with a +4 diopter? For example the Nikon lens’s minimum focus distance is 11.8†(30 cm) with a max. ratio of 1:8.3.
  2. If the dioptre and dome are perfectly matched. Nothing.
    However most domes require theoretically weaker dioptres than the +4. To make a sweeping generalisation, most 8 inch domes theoretically require +2 (although this is not always what gives the best performance).
    Therefore a +4 will increase the maximum magnification ratio a little. To pluck a number out of the air - maybe to 1:7??
  3. If the dioptre and dome are perfectly matched. Nothing.
    Thanks Dr. M. I am sure your plucks are better than my plucks.
    Regards,
    Bob
