One of my favorite cameras is my Horizon 202 swing-lens panorama, which is (pretty much) the Russian copy of the Noblex. It's sort of like a reverse of a Cirkut, whereas instead of the whole camera rotating, the lens rotates to expose a 24x58mm film frame over ~130 degree field of view.
Basically, the issue is housing it with a port that works. To that end, probably a cylinder port would be what is needed, since it would be perpendicular to the lens axis throughout the rotation.
[To that end, think of putting a Cirkut, a Hulcherama, or a Roundshot inside a glass jar with the nodal point along the axis.]
To see a sample of my work, go to page 5 of this PDF; or see below.
Anybody? ![]()
Dan Schwartz
Sayreville, NJ
