Manual flash control on Subal ND20
Started by paulli ·
  1. Manual flash control on Subal ND20
    I have created a bracket for the Mode Dial to control the flash compensation button.
    Now I can use the manual mode on the iTTL converter from www.heinrichsweikamp.net
    (Sea and Sea)
    Regards
    Paulli
    post-6115-1193155902_thumb.jpgpost-6115-1193155929_thumb.jpgpost-6115-1193155946_thumb.jpgpost-6115-1193155963_thumb.jpg
    post-6115-1193155980_thumb.jpgpost-6115-1193155996_thumb.jpgpost-6115-1193156012_thumb.jpgpost-6115-1193156029_thumb.jpg
    Copy from HeinrichsWeikamp manual for Nikon OEM converter
    Enhanced manual strobe control (M-TTL):
    Operation in this mode gives the ability to use non-doubleflash compatible strobes with the converter.
    Furthermore allows this mode for enhanced photographic composition with all TTL
    strobes provided with only minimal or non-existent manual control.
    Activation:
    -set strobe to TTL
    -set camera to synchronisation on second curtain (REAR)
    or
    - set adjusting knob on the converter to global manual mode
    Flash power selection:
    The flash power is selected by using the flash exposure compensation and the exposure compensation.
    The result is the sum of both values. Hence the M-TTL flash power can be adjusted
    by either the exposure compensation (EC) or the flash exposure compensation (FEC) of the
    camera. The flash power is halved every -1.0 EV. In case both, EC and FEC, are set to +/- 0 EV,
