Alternative viewfinder for Ikelite DSLR housing
Started by scottleslie ·
  1. Has anyone found an alternative viewfinder that can be adapted to an Ikelite DSLR housing (specifically for 400d) to improve the view? Any other suggestions would also be welcomed. I am using the same low-profile scubapro frameless I've had for years to get my eye as close as possible. Maybe there's an even better mask for this out there? Thanks very much.
    Scott
  2. Has anyone found an alternative viewfinder that can be adapted to an Ikelite DSLR housing (specifically for 400d) to improve the view? Any other suggestions would also be welcomed. I am using the same low-profile scubapro frameless I've had for years to get my eye as close as possible. Maybe there's an even better mask for this out there? Thanks very much.
    Scott
    hello
    you can see that : Plongimage
    it's a french reseller, but i think they accept orders from everywhere
    best regards
    Jean-Christophe
  3. Thanks Jean-Christophe
    hello
    best regards
    Jean-Christophe
  4. Check Backscatter's website - they put the viewfinder into the housing so that the eyepoint is in the specified location, as opposed to just clamping it on to the outside. I think this makes a difference to the quality of the view but haven't tried each myself.
  5. Has anyone found an alternative viewfinder that can be adapted to an Ikelite DSLR housing (specifically for 400d) to improve the view? Any other suggestions would also be welcomed. I am using the same low-profile scubapro frameless I've had for years to get my eye as close as possible. Maybe there's an even better mask for this out there? Thanks very much.
    Scott
    To add to what James said Backscattr Custom Shop Inon though part of the page is not showing up right now.
    Edited by TheRealDrew
