Ikelite Strobe: TTL Slave sensor, Tray, Arms - 4Sale
Started by lanwu ·
  1. Will ship overseas. Payment & shipping costs can be arranged for interested parties.
    Strobe, housing & camera in picture below is not for sale, but for usage example only.
    Ikelite Arms & Tray
    ... - Tray Arm: 11 inches
    ... - Tray Arm extension: 4 inches
    ... - Extension Arm: 13 inches
    ... - All parts as seen in photo
    Ikelite Underwater TTL Slave sensor:
    ... - Eliminates the need for a dual sync cable in dual flash systems and provides full TTL functionality.
    ... - Triggers from the internal flash of cameras with no external flash connection.
    ... - Max. Operating Range: approx. 15m underwater (sensitivity adjustable).
    ... - Must be connected to Ikelite DS-series Substrobe, but can be triggered by a master flash of any make. Detects firing and quenching of master flash, and signals the Substrobe to fire and quench in sync. with it.
    ... - Exposure accuracy: ± 1/10 EV.
    ... - Mounts on standard Ikelite ¾†diameter arm stem or tube. Other mounting options discussed below.
    ... - Dimensions: Body diameter (at front window): 45.5mm, Front to back: 79mm, Height inc. mount: 105.6mm
    ... - #4100.5 TTL slave sensor for Ikelite DS-series ("digital") substrobes (DS-50, DS-125).
    ... - Reproduces digital camera pre-flashes.
    ... - 4100.5 connects with DS-series strobes only.
    ... - Powered by the DS-series substrobe. Does not require batteries.
    ... - Pre-flash intensity switch (4100.5): Located beneath removable plug with coin slot.
    ... - Right position (shown) is for cameras using pre-flash. Provides long pre-flash to reduce chance of overexposure.
    ... - Left position is for cameras which do not use pre-flash. Also provides shortened pre-flash with pre-flash cameras, increasing exposure.
  2. Hello. How much for the #4100.5 TTL slave sensor for Ikelite DS-series ??
    Thanks.
    My best regards
    Ikelite Arms & Tray
  3. Here's some pics of the items.
  4. Here's some pics of the items.
    Is the Ilkelite TTL Slave Sensor stiill for sale? How is the sensor best attached to the arms. I would be using it with a DS125 and DS51. What price for the slave sensor?
    Rick M
