SplashCam Deep Blue Pro Underwater Video Camera System
Started by carol.comm@gmail.com ·
  1. Read all about it at: http://www.splashcam.com/Deep_Blue/db.htm
    I purchased this system about a year ago for about $2,000.00 and have only used it once or twice. Excellent condition. Includes
    SplashCam Deep Blue Pro underwater marine video camera
    250' umbilical cable & reel
    Cigarette lighter adapter
    Stabilizer fin
    Camera rotation handle
    Stainless eyebolt
    6.8" LCD Monitor (45M068X) ibcluding:
    2x A/V cables (female RCA audio, female RCA video)
    mini plug A/V connector
    Base Stand
    12V DC Power Supply
    Auxiliary Lighting Pod (LP-100_
    Pelican 1550 waterproof plastic case
    $1250.00 US$ for everything. Shipping additional - insured UPS Ground Shipping priced according to delivery address.
    Manufacturer's Description:
    The Deep Blue Pro Color is Ocean Systems' most popular and highest quality underwater video camera. You will be amazed with the video quality and versatile design of this outstanding underwater video system. No other underwater video system on the market today can match the quality of the Deep Blue Pro color camera. Utilizing all digital signal processing and military grade umbilical cable, the picture produced by the Deep Blue is stunning.
The Deep Blue Underwater Video Camera is designed to be deployed into the water by itself. The high strength umbilical cable will support up to 700lbs of dead weight, which allows you to add ballast weight to get real deep if needed. You may also mount the Deep Blue to a down-rigger or to the end of a telescoping handle. The underwater camera will provide broadcast quality video of the underwater world back to the surface to be monitored in real time or recorded for later viewing. You can get up to 1000 feet of cable.
The Deep Blue underwater camera is rugged as well, able to withstand direct impact from rocks, cables and other debris. The Deep Blue will last for years to come.
    Features:
    Super high resolution color picture
    Low Light Operation
    Virtually Indestructible Underwater Camera Housing
    Military Grade Umbilical Cable
    Xenon Technology Underwater Lighting
    Hand Held Reel For Easy Deployment / Recovery
    Recessed Lens Borsolite Lens Will Not Scratch
    Ability To Attach Up To 10 lbs. Of Ballast Weight
    No Installation Required, Fully Portable
    Camera Specifications:
    Image:
    NTSC Composite Video (PAL Optional)
    Auxiliary Lighting:
    Removable Battery Operated Light Pod
    Resolution:
    520 TV Lines
    CCD:
    1/3" Sony Super HAD
    Focus:
    Fixed 1 inch to Focal Infinity
    Lens:
    3.6mm Wide Angle
    Iris:
    Electronic
    Operating Temp:
    -10 to 55 C
    Light Sensitivity:
    0.15
    Input Voltage:
    12 VCD
    Current Consumption:
    210 mA
    Output Signal:
    Standard Composite Video / Female RCA Jack
    Physical Specifications:
    Body Construction:
    Cast Aluminum
    Exterior Finish:
    Anodized / Thermoplastic Paint
    Camera Head Weight:
    2 lbs in air / 1.2 lbs in water
    Depth Rating:
    Standard: 800 feet / Upgrade: 2000 feet
    Overall Weight:
    With 100 feet of cable 10 lbs
    Umbilical Cable Tensile Strength:
    700 lbs break / 250 lbs nominal
    Cable Entry:
    Standard: Compression / Upgrade: Underwater Plug
    Max Cable Length:
    1000ft. stock / 2400ft. special order
    Camera Dimensions:
    3" diameter / 3.5" length
  2. I'm interested is it still for sale,call me 323-363-5411 or email me at lpcity77@aol.com
    Stabilizer fin
    Stainless eyebolt
    Base Stand
    12V DC Power Supply
    Features:
    Low Light Operation
    Image:
    Auxiliary Lighting:
    Resolution:
    520 TV Lines
    CCD:
    1/3" Sony Super HAD
    Focus:
    Lens:
    3.6mm Wide Angle
    Iris:
    Electronic
    Operating Temp:
    -10 to 55 C
    Light Sensitivity:
    0.15
    Input Voltage:
    12 VCD
    210 mA
    Output Signal:
    Body Construction:
    Cast Aluminum
    Exterior Finish:
    Camera Head Weight:
    Depth Rating:
    Overall Weight:
    Cable Entry:
    Max Cable Length:
    Camera Dimensions:
  3. Read all about it at: http://www.splashcam.com/Deep_Blue/db.htm
    Stabilizer fin
    Stainless eyebolt
    Base Stand
    12V DC Power Supply
    Features:
    Low Light Operation
    Image:
    Auxiliary Lighting:
    Resolution:
    520 TV Lines
    CCD:
    1/3" Sony Super HAD
    Focus:
    Lens:
    3.6mm Wide Angle
    Iris:
    Electronic
    Operating Temp:
    -10 to 55 C
    Light Sensitivity:
    0.15
    Input Voltage:
    12 VCD
    210 mA
    Output Signal:
    Body Construction:
    Cast Aluminum
    Exterior Finish:
    Camera Head Weight:
    Depth Rating:
    Overall Weight:
    Cable Entry:
    Max Cable Length:
    Camera Dimensions:
