i used to work with a subal housing 5 D since january....but i had a probleme with position button on the housing..it's not easy to move it..the position is very boring..either speed button on manual mode or diaph button on mode A
So...have you ever find a solution to work better ?....Do you think seacam housing 5 D is better ??
Thanks a lots..
Laurent
The ergonomics of the Seacam 5D are perfect - all controls at your fingertips. However, it is larger in size than the Subal - although this may mean it's lighter underwater.
Thanks James..
It's a big problem for my fingers....i thought the position button was more near than the qtarter but ...
If i can't find a solution, i'll buy seacam housing...
