I'm looking at getting a strobe to go with my Canon A630 (in Canon housing), and the Sea & Sea YS-27DX seems to be what I want. However, the only optical sync cable available is the "L-type", which looks like it plugs into the housing. Does anyone know if this cable is compatible with all housings (by sticking to the outside of the housing and detecting the flash), or is it only compatible with Sea & Sea housings that have the appropriate port? Also, does anyone know how long this cable is?
Alternatively, can any recommend any other cheap, simple (non-TTL) strobes like this?
Thanks.
If you buy the YS27 new it comes with two mounts which when used in conjunction with the sticky black velcro (dual purpose - 1. blocks internal flash. 2. fastens the mount to the area of your choice) will allow you to use the L type connector. The cable is only about 15" long but is in a coiled format that stretches comfortable to a little over 2ft. The problem I've had with these cables is their light through put isn't the best. You can hold one end up to a table lamp and should see good light coming through it. Some barely had any right out of the box. Re-terminating them fixes that but it isn't easy to do. You need some small roll pins from the automotive store then you have to cut them to size and crimp them on the newly cut cable.
I just 'upgraded' my old mk1 cables to the newer 'L' cables for my YS-25s and they operate flawlessly. They seem to be a much better construction with right-angled plugs and a heavier grade of cable.
I just use black tape to secure the 'socket' to the outside of my Fuji housing for a Fuji F30. Then I just plug in the cable. Works fine. Tape holds the cable securely in place over the onboard flash and otherwise blocks the output from the onboard flash.
What's the deal with the velcro? The dealer who sold me the lens set me up with velcro, but i don't understand why. What do you velcro to what??
