I bought my Sigma 15mm FE at the beginning of this year, just before the “rage†or should I say reign of the Tokina 10-17mm FE began. I use the sigma on a canon 20D in ikelite, still using the small 5503 port.
Since everybody is so excited about it, I am wondering if I should trade in my Sigma. I can probably do that almost budget neutral or for a minor amount (since the list price of the sigma is higher then the Tokina). Since I got quite a good deal on the sigma, I might even be able to exchange it neutral.
The reasons why I should are easy, is of course coverage and flexibility….but I can think of several reasons why I shouldn’t:
- Wide angle is still a weak point, at which I need way more practice. Not going more extremely wide and not using a zoom but a prime keeps the amount of variables short.
- F2.8 is better for autofocus in Dutch murky conditions….
- I already have a whole set of magic filters for it (which I haven’t used much yet, sorry Alex), magic filters on a canon mount Tokina are finicky.
- New lens, will need practice anyway…
- With some care, I can use the sigma topside as well. Apparently, the tokina suffers from CA which limits above water use (although correctable in post)
- I have two DS-50 strobes, which can cover the cropped angle of view of the Sigma without diffusors (or more easily with them). On the Tokina 10mm, I would definitely need the diffusors (80 degrees coverage with diffuser, 70 without). Especially at strobe placement, practice is needed…..
Theoretically the last one is feasible, the horizontal angle is 137 degrees and the DS-50 with diffuser is 80 degrees allowing for some overlap. According to the ikelite specs, the coverage represents a one stop difference between centre and edge (so there is still some light beyond that).
Has anyone any experience with similar small angle strobes and the Tokina? I need to be either become very handy with strobe placement (not so well until now) or buy other strobes. If the last one is really needed, I probably wont do it.
What are your thoughts in this situation ?
edit (finally edited the annoying fonts away (was copied from MS Word)
a shot with the 15mm FE in the less murky conditions of the atlantic (Bretagne)
