Woody's Diopter vs Inon UCL165 close-up lens
Started by pakman ·
  1. While looking at the Athena Optical website lately, I noticed they sell a new S&S port for the Canon 100mm Macro and Nikon 105VR that have 67mm threads on the end, allowing screw on close-up lenses such as the famed Inon UCL 165 double element close-up lens.
    The Woody provides approx a +20% magnification. What is the magnification factor on the Inon closeup lens? Edit: think I might have found the answer. Is the Inon 165 equivalent to a 2x and the Inon 330 1.3x?
    http://www.athena-opt.com/kougakue.htm#100usm
    Edited by pakman
  2. hi pak,
    yes it's x2. my INON ports also have a m67 skrew and i use the ucl 165 frequently. i am very happy with it in supermacro ...
  3. thanks Serge.
    Do you use that 165 with a Canon 100mm macro?
  4. i use it with the:
    - ef-s 60mm macro (working distance quite short there, but easy for small nudies, flatworms etc).
    -100mm macro (very easy to use)
    -100mm macro + 1,5 kenko teleconverter (little bit tricky but nice magnification)
    this pic is taken with 100mm + 1,5 tele + ucl 165 ...
  5. Thanks Serge. Hmm... maybe I should give my 1.4x TC a try. What is the min focus length with the TC on (without the Inon 165 on)?
  6. the minimal focus distance does not change with a tc ... so it is the same as with only the 100mm. but as it is measured from the chip it is actually a little bit closer to the port, than without the tc, because the port with the tc is a bit longer.
  7. Image one, Olympus 50 mm macro with 2 X tele converter (200 mm 35 equv.) fully extended e.g. 2:1.
    Second image same equipment, fully extended 2:1 with the Inon M-67 165 C/U lens on an Inon macro port which like the Athena port also has the 67 mm threads.
    Phil Rudin
