Sea & Sea DX1G and wet Macro Lenses?
Started by eskasi ·
  1. Are there any Macro lenses out there which will fit the DX1G for even greater magnification (or less need to get as close)? Inon makes them for the Ikelite housings.....some even double stack them. Anything like this out there (with adapters) for the DX1G?
  2. Are there any Macro lenses out there which will fit the DX1G for even greater magnification (or less need to get as close)? Inon makes them for the Ikelite housings.....some even double stack them. Anything like this out there (with adapters) for the DX1G?
    as far as i know there is not , i understand the dx1g uses bayonet mount lenses have you thought of getting a 2nd hand inon ADmount macro lense and trying to do modification to make it fit ?
  3. I would certainly like to try.....I was just hoping someone had tried it before and had some kinda blueprint....
  4. These are the first shots with the camera.. Most are in Macro mode.. Not super macro.. Haven't tried that yet.
    Not sure about the camera yet.. Much different that the the D-70 setup..
    What do you thin of the shots?
    Kona - DX-1G
    Joe
  5. These are the first shots with the camera.. Most are in Macro mode.. Not super macro.. Haven't tried that yet.
    Kona - DX-1G
    Joe
    Nice shots. I'm curious about the particulars of the photos. Manual or Auto mode? F/stop - shutter? How's the shutter speed lag compared to your D-70? Were you using your dual-strobe setup with it? Using RAW mode?
    Sorry for all the questions, but these are the first photos I've seen with the DX-1g using external strobe. The camera looks like it might be a real winner for a consumer digicam.
    thanks!
    John
  6. Here is the close up lens and ring offered for the DX 1G housing. Hope this helps.........
    acce_closeup125.jpgwhite.gifClose-UP Lens 125
    (Product No. 52119) • Lens construction: 2 elements in 2 groups (multi-coated)
    • Focal length: 125mm (equivalent to close-up lens No.8)
    • Dimensions (DIAxD): 74x9.5mm / 3x0.4inch
    *The Close-UP Lens Ring is required to attach to the DX-1G housing. (Magnification can be multiplied by stacking them.)
    acce_closeup_ring.jpgwhite.gifClose-UP Lens Ring
    (Product No. 58119) A set-up ring to attach the Close-UP Lens 125 to the DX-1G housing
