What do you use to reduce flash beam?
Started by Mikel ·
  1. Hello,
    I am thinking of putting something in my flash to reduce its beam to have more selective light. I have no found anything to put in it so I think this is a DIY proyect.
    Searching in wetpixel I have found little information about that. And just one article about that in UWPM, in the 24 issue.
    My idea is to adapt a piece of PVC to my flash:
    Any other ideas?
    Do you use or have ever used it? Pros and cons?
    Thanks a lot,
    Mikel
    Sorry for the English, it's my 3rd language :angry:
    Edited by Mikel
  2. Hi Mikel,
    Good job with the English. The device you are talking about is called a "snoot."
    For something simple, you can cut off the arm of an old wetsuit and use it in this way.
  3. Thanks James!
    That is what appeared in UwP 24, a flash taped. I am not sure but I think that is not the best way to make a "snoot". Do you use like that?
    My "idea" is something like this:
    http://www.honlphoto.com/servlet/the-6/spe...sh-nikon/Detail As you have said, they call snoot.
    I also have read that with a kind of honey comb, the light is concentrated too and you don't need a long tube to reduce the beam:
    http://www.flickr.com/photos/71265688@N00/...358068593/show/
    The problem is that I do not know how to use/adapt it underwater and how it will work.
    A good example of the result of what I am looking for:
    http://www.fotonatura.org/galerias/fotos/142013/
    A sandy area where you don't want a lot of light.
    Regards,
    Mikel
  4. Mikel,
    I know what you mean - sometimes you dont' want to light up the background.
    You are on the right track. You can buy something called "egg crate" to make a grid for the inside of your snoot - to further help you control the light.
