It points down on my 20D housing, I want it to point up so that there isn't as much strain on the cable. There is a small pin so I would need to drill a small hole in the housing to rotate the bulkhead so Im a little leary.
Phil
Started by Phylo ·
Phil
Have you contacted Ike ?
I agree , something like 10-12 oclock position would definitely save some wear & tear on the cable. Mine seem to get mangled after a dive when a someone in the boat crew sets the rig down on the cable. I'm not blaming them , they just don't realize how fragile that part really is. The set-up should be modified. Maybe Ike can make an adjustment.
VB
Have you contacted Ike ?I agree , something like 10-12 oclock position would definitely save some wear & tear on the cable. Mine seem to get mangled after a dive when a someone in the boat crew sets the rig down on the cable. I'm not blaming them , they just don't realize how fragile that part really is. The set-up should be modified. Maybe Ike can make an adjustment.
VB
I Ihave not contacted them yet, but I think all there new housings come that way now.
Phil
