I can't really answer your question because I have never seen this lens or heard of anyone else using it.
The specs do not really entice me to use it. It may be fine, but the close focus of only 30cm and 1:4.6 magnification ratio would frustrate me a bit. It also looks a bit big and heavy for a lens you may not want to use that often. I would guess a 40mm port ring is the minimum you would need.
Mid range zooms do not excite a lot of underwater photographers although I like the idea a lot. I went for the new Sigma 18-50 F2.8 macro and have found it very useful on certain subjects. However they are not always easy to house and get an optimal configuration behind a dome port. I have used mine behind both a dome and a flat ports depending on the subject I'm after.
If you can I would recommend taking your housing in to a camera dealer and trying the combination out before commiting yourself. I'd be interested to hear if you get it and can report back.
I am thinking again about a mid range zoom but I would now prefer a slightly longer zoom range to work behind a flat port. However, I'm not sure the ideal zoom that meets my needs exists yet.
