Magix Movie Edit Pro 12 problem
Started by Wet Eden ·
  1. When I play a movie in storyboard and I want to cut a scene, I pause, go up to Edit, click and select "split object". This use to work fine but after the first movie it started sticking. The clip starts of fine until I split it, after that it sticks and I cant use the rest of the clip.
    Can you help with this?
