Ikelite housing without waterproof cap?
Started by LekicINC ·
  1. Hello, is it possible to use the ikelite housing without the waterproof connected to the camera and NO ttl cable installed to it. I bought the housing and ds50 substrobe for the 5050 but it didnt come with a waterproof cap. Am I forced to use the ds50 substrobe with it just so I can prevent flooding? I am pretty sure I know the answer (otherwise they wouldnt call it a waterproof cap) but hoping someone may have a solution since I leave for my trip tomorrow!
    Edited by LekicINC
  2. dont use it like that unless you want to drown it. It may not be fast, but it will happen. Did the DS-50 come with a waterproof cap? You can use that one (they have the same fittings). You wont bring the DS-50 in the water without the sync anyway.
    When using a cap under water: apply the same care to oring cleaning and closing as when attaching a sync.
  3. dont use it like that unless you want to drown it. It may not be fast, but it will happen. Did the DS-50 come with a waterproof cap? You can use that one (they have the same fittings). You wont bring the DS-50 in the water without the sync anyway.
    Ahh brilliant idea! My only problem now is removing the cap! I cant seem to figure this out. :blush: I may just end up using my old set up because I am little nervous, but I really appreciate your speedy help.
    Now I am confused: we are talking about this cap arent we? This just screws loose. The waterproof fitting is the o ring. If the cap is stuck on the DS-50 , how would you be able to fit the sync.
    Anyway, if it is just use a little more force, and use fabic or a rubber band to increase friction.
    ERRR, now im really embarrassed. I didnt realize you had to pull. I should call my mother and ask if i was dropped on my head as a child. Again, I really appreciate your help in solving both my problems with common sense!
