Lens clear solution for housing?
Started by nickough ·
  1. Hi there - newbie here!
    I recently started to use an underwater housing for surf photography.
    Does anyone have any tips about a product to put on the lens of the housing to assist water drain off. I used to use this stuf called 'Rain x' on the windscreen of my car which made the rain water drain off easier, is there a similar product for housings. I want to reduce the water/droplets as much as possible when taking shots above the water line??
    :excl:
  2. RainX is not recommended to acrylic ports.
    What work quit well is babying shampoo, from some reason the Johnson & Johnson is the one that usually recommended for that.
  3. RainX is not recommended to acrylic ports.
    Hi - just to clarify, I am looking to put something on the 'outside' face of the housing lens to assist water run off, does baby shampoo apply to this?
    Thanks :excl:
  4. As Arnon says, Baby Shampoo works well. Also great as a defog for a mask. Cheap, and smells nice. For your dome, smear some across the dome, rub it around a little over the whole surface, then briefly rinse.
    For a mask, I do not recommend generic, only Johnson & Johnson, some of the generics are not as gentle on the eyes.
    Edited by loftus
  5. I use a slice of pineapple and smear it over the lens before the dive if available.
    But then again they do grow on trees around here :excl:
  6. I use a slice of pineapple and smear it over the lens before the dive if available.
    Don't make me hate you :excl:
    Pineapple is for me, not the port!
