This is a complete setup - zero-to-hero in underwater photography. Perfect for a beginner looking for something you won't outgrow.
The digital camera was the first digicam capable of serious U/W application, due to it's true TTL metering and 19mm very Wide Angle lens. This camera takes excellent images, with adequate file sizes (5MP). I use it every week for topside photography, food photograpy, etc.
Camera -
Nikon Coolpix 5000, Nikon wide angle lens, barrel adapter, UV filter, SB-80 Flash, custom flash diffuser, pop-up lens hood, universal voltage compact charger with 5 batteries, USB cable, 512MB and 256MB compact flash cards, Lowe Prowe mini bag, Lowe Pro full size bag, all original hardware and boxes. Also an aftermarket manual specific to this camera, with CD.
Housing -
Aquatica 5000 housing, with leak alarm, single baseplate with foam grip, double baseplate, custom grip handle, quick release handle, two full sets of arms with extensions, modeling light arm, double set of O-rings, lube, standard/macro port, wide angle dome port, custom port covers.
Strobes -
2 Nikonos SB-105s (recall replacement strobes), Nikon single sinc cord, Nikon dual sinc cord, double set of O-rings, lube, 2 diffusers with custom retainers, accesory cord caps.
Portable digital storage -
10GB X-drive II portable drive, with Universal charger, USB cords, Custom soft case, Pelican hard case. Great for backups or dumping full CF cards.
Camera is well used but in very good condition, glass is in excellent condition. All U/W gear is very little used (no longer diving) and in As-New condition all around. All glass is excellent condition.
This was over 4 grand new, 750 is a very good value. You can't get into UW for less than this.
Check out my ad, with photos, on Craigslist - http://vancouver.craigslist.ca/spo/520714251.html
Rob.
