I have got a Canon G7 in the Canon brand housing and have had this setup for about a year. More recently, I have realised that I need a wider angle lens (and a strobe, but thats another story) because a lot of the things I like to photograph underwater such as fish schools and stingrays simply wont fit in the frame without having to back up, which makes the pictures look crappy because the water is not so clear.
I understand that you cannot have wide angle on the canon housing because it has too much zoom, which will cause vignetting. But how intense is it? If I zoom in to, say 45-50mm, and I had the ikelite X0.56 wide angle lens would the vignetting be still uncorrectable in photoshop? Also, I dont mind (very?) slight darkness around the edge of the frame.
I have tracked down an 67mm threaded adapter for the canon housing and this would fit the Ikelite wide angle lens I want. Also I am aware of the Ikelite housing which limits zooming but at 700USD it is too expensive (student budget). So would this work at all, if I correct the vignetting in photoshop or some other photo editor?
EDIT- Also, would there be less vignetting if I set the lens to small F8 aperture instead of a larger aperture like F2.8 or F4?
