16-35mm canon blur corners
Started by tuba ·
  1. Hello
    Does anyone have the right setting for a canon 5d and 16-35mm MKI to have sharp corners???
    My housing is an aquatica with 8" dome and I use the ext ring adviced by aquatica but it is not satisfactory
    a +3 diopter???
    thanks for your answer! :P
  2. Still fighting mine.
    Different housing and I even calculated the entrance pupil.
    I'm thinking we are chasing dragons at this point.
    Perhaps a diopter is necessary...
  3. If the dome is positioned properly (the center of curvature is located at the entrance pupil) & edges are still soft, then a diopter is needed, even if the lens focuses ok. I'm using +3/+4 on my 12-24 & 17-55 Nikons.
  4. thanks for your answers I'll try with a +3 diopter
    I 'll be very interested to know if somebody with a 16-35 mm using a +3 dipoter has good results (as the manufacturer do not advice to use one)
    Is a larger dome (9") maybe the solution?
    a great idea probably would be to have a "zoom extension ring"! but still does exist on the market
  5. i find the corners on the 16-35 horrible at wider apertures even on a 1.3x 1dmk2, and i don't even use the lens underwater! a +3 diopter i'm sure is a must with this puppy. stop it down as much as possible to help the corners too, go for f8-f11.
    be careful not to buy a diopter with a thick mount, as you could get vignetting at 16mm on a 5d.
  6. which filter brand would you recommend that does not have thick mount, B&W?
    Edited by tuba
  7. i find the corners on the 16-35 horrible at wider apertures ....... go for f8-f11.
    When I had the original version of the 16-35, using f16 was the only way I could get acceptably sharp corners on land.
    I tried a few combinations when I used it on my EOS 50 (remember film?) underwater in a Subal housing but was unable to get sharp corners at any aperture that was usable underwater. :ninja:
