Seatool 40D Housing
Started by pakman ·
  • 19Posts
  • 19Replies
Seatool 40D Housing
  1. Looks like it's available in Japan now
    http://seatool.net/list/40d.htm
    pdf file on the housing available as well but it's all in Japanese.
    just some highlights.
    list price:JPY 268.000
    2 fiber optic ports standard (2 Nikonos bulkhead optional)
    Access to all 40D buttons [correction: no access to the joystick or the AF-On button]
    Rated to 60m
    Focus/zoom dial on body
    (internal strobe lever - to mechanically close the 40d internal strobe)
    Port lock
    In addition to a coldshoe on top, there are two slots for ball joints on top of the housing accesories/ arms.
    available in Black or Silver
    dimensons: W210mmXD123mmXH164mm
    Weight: 1.7kg
    one more thing: looks like it has a button for popping the lens off without having to remove the camera body.
    Edited by pakman
  2. I've been diving a housing for a few weeks. We are awaiting a few more finishing touches before offering this in the US, but I expect it will be ready in a week or two.
    You are correct, AF-ON isn't offered. This is mitigated by the ability to switch the function of the AF-ON and Star Buttons in the custom menu, and the banks of custom settings to automate this.
    I dived the setup in Bonaire w/ 5" arms mounted to each of these base adapters, and a focus light in the cold shoe. This was actually a really sweet setup for macro shooting, and was very light in the water. Somewhat reminiscent of the midsize digicams of years past.
    Ports are a work in progress. They'll be delrin to save weight, and initially a dome, 60mm Macro Port, and 100mm Macro port are available, with more accessories on the way. Port converters are also available for Subal, Sea & Sea, Nexus, and Inon. Aquatica is being done as well, but isn't finished yet.
  3. I've been diving a housing for a few weeks. We are awaiting a few more finishing touches before offering this in the US, but I expect it will be ready in a week or two.
    Considering that I ordered a 40D this morning, this is exciting news. Have they gotten it down below 12 pounds yet? :D Just sent you a note via the webform on your site . . .
    Mike
  4. Ah Ryan I suspected you would be the first to respond :D
    Do you know how many extra mm the S&S port adapter adds? At the moment, I'm still leaning towards the S&S 40D housing and I still have a good investment in S&S ports and optical dome.
  5. Way to go Mike - you bought a new camera!!!! Is your 10D sitting on the shelf pouting yet :-)
    The housing looks smashing - great news. I'm glad Seatool is increasing their housing lineup to include the 40D
  6. Way to go Mike - you bought a new camera!!!! Is your 10D sitting on the shelf pouting yet :-)
    The 10Ds aren't sure what to think. Part of me is thinking I should keep at least one and the housing just in case. I could probably get $300 a piece or so for them on eBay, but I fear the housing may be worth little or nothing. Hard to part with the 10Ds as they've been great cameras for several years. Yes, the Seatool housing does look nice. I had a chance to play briefly with Ryan's prototype in Bonaire and it was pretty cool, though it was a bit heavy and needed some ergonomic work, as Ryan alluded to in his post. Hopefully he's set them straight and there will be a "real" housing soon. I think Ryan is in a rush to get the 40D one final so he can move on to getting them started on housing his D300! The S&S housing is also an option, though I like the fact that the Seatool is built with fiber optic strobe connections in mind.
    Still need to get the final word on how much the S&S port adapter adds to the overall length. I think that when I was in the shop in November, Ryan said it wasn't as much as he first thought . . .
    Mike
  7. Interesting comment on the weight. 12lbs? Is that total with camera and ports?
    Here's a quick comparison of weight and dimensions between the Seatool and S&S 40D based on specs released on their Japanese websites.
    Weight
    S&S's 40D is listed as 2.7kg on land (housing only)
    Seatool 40D is 1.7kg... [edit: this is weight in water w camera body, 18-55 lens, and port]
    Dimensions
    S&S W317mmxD137mmxH168mm
    Seatool W210mmXD123mmXH164mm
    Pretty close, S&S is just a tad bit wider and deeper.
    If the actual weight isn't that much different, I'm going to have a tough time making a decision. Unless the Seatool S&S port adapter throws off my dome port positions too much.
    Edited by pakman
  8. Interesting comment on the weight. 12lbs? Is that total with camera and ports?
    Sorry, that was one of my (typically) lame attempts at humour. It did seem heavy to me when I handled it but I really have no way of verifying the actual weight. And it did have the camera in it and a flat port on it. Ryan said they still hadn't worked the wall thicknesses down to their final values yet so I would expect the final version to be somewhat lighter than the prototype.
    Mike
  9. ahahaha... you had me worried there Mike!
    Well the 40D is got some good heft to it by itself so i can imagine these housing being pretty negative. Kind of like some of the D200 owners complaints with some alu housings.
  10. Mike,
    Stu's friend Bill Reed makes a 10D to 5D conversion kit that works very well (it's made for Subal). Don't know if it will work for Sea and Sea but don't sell your housing w/o talking with him eh?
  11. Well looks like Yuzo has the S&S 40D housings in stock already in Japan...
    Tough decision. Would be interesting to try the Seatool, but I think I'm leaning towards going back to S&S housing.
  12. The port converter on the XTi housing moved the Sea & Sea NX Mount about 4mm forward. The goal on this housing was to place it in exactly the same spot, but we haven't seen one to confirm yet.
  13. According to Fisheye, Seatool's housing C40D has four viewfinder options:Besides Standard Viewfinder, optional Pick-up Finder, INON Straight Viewfinder and INON 45 degree angled viewfinders also available :D
    http://www.fisheye-jp.com/c40d/index.html
  14. Looks like Backscatter will install the viewfinders on the Sea & Sea if you want to go that way. The S&S site has the manual for the 40d housing up on line if you want to take a look at some details. (Service area) First S&S housings have started to hit the US this week.
  15. Looks like Backscatter will install the viewfinders on the Sea & Sea if you want to go that way. The S&S site has the manual for the 40d housing up on line if you want to take a look at some details. (Service area) First S&S housings have started to hit the US this week.
    got a link Steve on that 40D manual. I can't seem to find it either the US or Japan S&S site.
  16. got a link Steve on that 40D manual. I can't seem to find it either the US or Japan S&S site.
    Try this Link to S&S
    It's under Maintenance& Service, then User manuals
  17. thanks Steve... I was little brain dead after 8 nonstop hrs of O2 admin and CPR training and didn't see the menu bar up top.
  18. I went to shop "umino-shiyashinya-san" to see Seatool C40D housing last week. Seatool C40D housing is very compact housing ;) ...How much smaller the Seatool 400 XTI housing is compared to C40D housing :) !
    Edited by Yoko Qno
  19. I visited BOOT (www.boot.de) today and visited Hugyfot, Subal, Ikelite, Sealux (no 40D50/D housing) and Sea&Sea. After fitting, testing ergonomy and size the game was between Sea&Sea and Seatool... since I already have a YS27DX flash (fiber connection only, no cash for a TTL flash at the moment) and the shop owner gave me a pretty good deal I went for the Seatool 40D housing with flatport ;)
    The price difference between the 40D and 50D housing was enough to add a 45 degree Inon Viewfinder ;)
    The Tamron 17-50mm f2.8 also fits behind the port for the 60mm macro.. So util I have a decent wide-angle/FE with dome I can use the Tamron at 17mm.
