Tokina 12-24 zoom
Started by bruceterrill ·
Tokina 12-24 zoom
  1. Hi Guys,
    I am looking at the Tokina 12-24 zoom as a viable alternative to the Nikkor 12-24 unit...Does anyone have any experience with this lens and any advice as to recommended dome port size?
    I was also after any general opinions as to the quality of Tokina lenses on the whole:
    Quality,
    Size,
    Chromatic aberration,
    Barrel distortion etc.,
    Suitability for U/W use,
    Recommended diopters, etc., etc.,
    I have very little time available to me for testing and even less chance of seeing one of these lenses before purchase, so I am relying heavily on the advice/opinions of my fellow u/w 'piccie' takers...
    Thanks for taking the time,
    Bruce... :D
  2. Hi Guys,
    Quality,
    Size,
    Bruce... :D
    I use the Tokina with my D200, have not used the Nikon, so no direct comparison, but am happy with sharpness and lack of distortion. I understan that from reading reviews, it isn't quite as good as the Nikon, but very close and the extra $400-$500 for the Nikon can be better spent elsewhere.
    I use a +2 diopter behind my big S&S dome port with a 40mm ext ring.
    S&S does not make a zoom gear for it, but I have found that the S&S 18-70mm zoom gear works great with if you remove the o-ring from the gear and wrap the zoom ring on the lens with a layer or 2 of electrcal tape for grip.
    I am very happy with this lens, it compliments the Tokina 10-17 fisheye very well, biving me that extra reach when I want it and is an awesome topside wide angle lens. Overall, it is one of my favorites.
    Hope this helps,
    John
  3. I like mine (for Canon) a lot. I also use it behind a Sea and Sea big dome but don't use a diopter. I haven't noticed much corner distortion and on land it is a very capable lens as well. I may switch over to the Tokina 10-17 underwater, but I do like the Tokina 12-24 as a wide rectilinear. I use a Canon 100mm zoom ring. I used foam carpet tape inside the ring to make it fit. Build quality is excellent, at least to my eye . . .
    All the wide angle pictures here:
    http://mikeoelrich.net/Bahamas_2005
    were taken with the Tokina 12-24mm.
    Mike
  4. I had one which I used with a Canon 20D and 1DmkII - I liked it a lot. I sold it when I got a FF camera.
  5. I use a +2 diopter behind my big S&S dome port with a 40mm ext ring.
    John
    What brand +2 diopter did you use? Where did you get it. The ones I've seen in that size are pricey.
    Jack
  6. JohnB, Mike and James,
    Thanks guys for your input. I appreciate your opinions and advice.
    I will follow up and source one of the lenses,
    Bruce... B)
  7. What brand +2 diopter did you use? Where did you get it. The ones I've seen in that size are pricey.
    I use the B+W +2 that I bought from Backscatter. It was a little pricy (~$70 I think), but so is everything associated with this hobby i guess....
    Take care,
    john
  8. I use the B+W +2 that I bought from Backscatter. It was a little pricy (~$70 I think), but so is everything associated with this hobby i guess....
    Take care,
    john
    Thanks John, $70 isn't so bad, the ones at B&H were like $200!
    Jack
