Ike Ds-125 Sea&Sea D300
Started by gadip ·
  1. First Question
    I have two Ds-125 strobes (serial number above 14,000) and I want to connect them to Sea&Sea D300 housing that I should get in few weeks ? I currently have Dual Sync Cord IKE part number 4104.62 will it works? or should I buy 4104.32 (new) ?
    Second Question
    I want to add for the above setup TTL. what are my best options?
    1 - Use Ikelite TTL p.n 0118?
    2 - Use Sea&Sea TTL version 2/3?
    Gadi
  2. The p.n. of the Ike TTL adapter you need could be #4302 (at least until D200), you should check with ikelite guys first, p.n. #0118 is for the o´ring only.
    My guess is that if you going to use ike´s strobes use the ike TTL adapter.
    You will need the double sync cord also with the blue band, but this will be an Ike to Ike sync cord= p.n. 4103.52, since you going to use the TTL adapter.
    Don´t take my word on this, I´m just guessing. Put an e-mail to Ikelite, for sure they clarify this to you.
    BTW, nice setup you have there. Looking forward to see how it works.
